Best cable for discharging Mac Plus CRT
I've never had a problem just using a regular runofthemill alligator clip with my screwdriver. Larry Pina suggests splicing in a large resistor, but even that's not really necessary.
Okay cool. I'm not going to add a resistor as the "pop" or spark sound is preferred (I've never done this before and I want to make sure I do it right).
Thank you for your help!
Same here, I've always just used normal alligator clips with a thick/large screwdriver.
Also may I ask about your Macintosh Plus with the fan mod? I was looking into that in the past. I too have a platinum 4MB, from 1990.
Are you discharging because you're going to work on the analog board?
If you only need to access the floppy drive or logicboard, it's not necessary to discharge.
Leaving it for a day or two will result in some discharge, yes.
I'm going to replace the RIFAs before they blow. Is it possible for it to completely discharge over time? How long would it take (estimate)?
Thank you for the help!
Most models include bleeder resistors that will progressively discharge the CRT. Which one is yours? A Plus?
In all the times I discharged a CRT I only had once a loud (and scary) Pop! when doing it to a Mac that was just turned off
Sure what would you like to know? I didn't perform the mod myself, it came to me that way.
Also you should be safe leaving it unplugged for 24 hours before opening.
Just what size the fan is, where it's placed and how loud it is. Thanks!
Mines a Plus, an international one. I guess leaving it for a few days is enough to avoid damage to the analogue board? I have no experience in CRTs or analogue boards so I just want to do it simple and then replace the RIFA caps and leave it alone after that.
According to this page (points 3 and 4), the Plus doesn't have the bleeder resistor.
It mentions damage to the logic board, but I heard reports of people damaging the analog board too...
Many people does it with a plain cable, but now I'm not confortable doing it again...
It does say that it should go to the ground lug and not the chassis, so maybe it would be okay? I am not able to make a special cable (I have no idea how). Perhaps leaving it for a week and then trying to discharge it?
Also another point to mention, Branchus creations uses a hand made discharge tool and he doesn't mention a resistor, yet uses it for his repairs on clients computers. Never seems to have had an issue with it. Could just be luck
The technique is always to attach the discharge cable to the metal frame of the CRT.
I don't think a week is necessary, but if you aren't in a hurry, 24/48 hours should be enough and then discharge.
For the cable I'm making I ordered these clips and these 1M resistors, then I'll solder using some cable I have around.
About Branchus... yeah, most people does this and myself I did it like that lots of times... and I just learn about few cases of damage, but...
Interesting. My Plus has been off since yesterday and I don't have any parts yet, so I'll wait until the parts arrive to do it (which should be a week with Australia's shipping at the moment).
I think I'll probably just wait until it's fully discharged and then do it the normal way. I might take the logic board out though...
Not the grounding screw? I've only heard people saying the ground screw and not the chassis... Perhaps thats how the guy broke his 128K?
All that should be connected... You'll see that the ground cable of the board goes always to the top-left corner of the CRT, that's where people clips the discharge cable.
(Found this random image... the "Yoke" is not that, but ok...)
