Unknown Radius board
Hi guys, I have found this board in my garage.
Do you have any idea of what is ?
while writing this post I found it could be "Radius Two-Page Display Card SE/30 (TPD SE/30) For use with the Radius Two-Page Display CRT."
I guess the video signal is output from the coaxial, may be there is the possibility to make grayscale the internal display ?
Thank you
Amedeo
Hi!
A bit late answer, you might have figured it out by now. It's a Radius Two-Page Display card for the SE/30 indeed. AFAIK, it's black and white only and it's intended to be used with a high resolution external monitor. The coax connector goes to a BNC socket at the SE/30's rear expansion slot.
