I am thiiiiiiiis close to springing for a Floppy-Emu, but I just have a few questions about how it works in practice. I thought about posting to Peripherals, but I don't read that board nearly as much as I read this one.
The manual on BMOW's site says that .img, .image and .dsk images all work, but that RAW (.dsk) images are ideal. What is the best tool to use to produce or convert-to .dsk images? I create some disks in mini vmac, and I've also made disks using DiskDup+; they both have .dsk extensions but look different in OS X, so they must have different file/creator ids. Also, are both Disk Copy 6 and Disk Copy 4.2 images supported, or only the latter? I have seen DC 4.2 images with both .image and .img codes. Basically, I'm wondering if there is one ideal set of file/creator codes that I should apply to all the disk images that I want to use with the EMU. I have a good variety of working classic systems ranging from 6-7-9 as well as modern OSX, so I'm game for using whatever disk utility is most recommended.
How does the Floppy EMU handle navigating through folders? Ideally, I'd like to have a small set of folder categories (e.g. Apps, Games, System). In the promo video it looks like there are folders on the SD card, but I'm wondering if they are easy to navigate.
I have found that some games don't play well under emulation (in mini vmac). Does this affect floppy-emu images, or is the Mac completely unable to detect that it is not reading a real floppy? Do games run at the same speed they would run if a real floppy were loaded?
What accessories do you use to plug the SD card into your modern machine to load up software? I have a 2011 MacBook Pro, and I have literally never used any kind of compact card with it. My machine seems to have a slot in the side, but I have no idea what would fit into it (it looks too big for SD). I don't mind buying a compact card reader, so hit me up with your recommendations.
I feel like I'm getting ready to bring a pet home...
