Got a 7100 that won't output video.
It chimes, the CPU gets warm and the BART chip (NuBus controller) gets warm, nothing else seems to.
Tried two different NuBus cards, PDS video card and onboard video (HDI-45) with no luck.
I have done the following:
- Replaced all electrolytic capacitors
- Tested without any RAM, so only using onboard 8mb
- Tested with nothing connected to internal or external SCSI
- Tested with no cards installed
- Reseated ROM, cleaned ROM socket/ROM card pins (already knew ROM was ok as I get a chime)
- Testing with a good PRAM battery
- Tested the PSU's output voltages, 5v and 12v are almost exact and stay that way
- Left it running for a bit, tried numerous reboots, tried PRAM reset, nothing made any difference
Looking at the block diagram, the common link betwen the external video, PDS and NuBus is the data path - but I'm not sure what to try/look at next?
