Back in the early 3D days people played games at 20-30FPS and were happy, now anything lower then 60FPS is unplayable and people want 100+ FPS. Don't think the switch from CRT to LCD had much to do with it or did it?
I'm kind of thinking that my Pentium 4 machine is beginning to show symptoms of bad caps....bad caps can cause big performance issues on Pentium 4s in my experience. When the VRM caps go bad I end up getting weird freezes and slowdowns that have gone away upon replacing them, mainly in trivial areas like the BIOS post or boot time.
Bad caps from that era bulge from the top or bottom and tend to be the ones around the CPU. Same thing with Athlon XP boards of the time period.OK. I looked and they don't seem to be bulging, but a few are slightly askew, which could suggest that they're bulging at the PCB end, where it may be less obvious.
I'll probably have to replace them sooner or later anyway, so I guess I better start planning for it.
It's a Via P4MA Pro, running at 400 MT/s with a Northwood 2.8 GHz CPU and 2GB DDR 233 (or 266?) RAM, if that matters?
c
