Figured looks like it might convert one floppy port to another connector and a DB19? Maybe for use in an LC?Some kind of floppy controller?
What about the second pin header? Has it ever been used on any Apple floppy drives?Ahhh... I *knew* it looked familiar. I don't have a discrete picture, but here's a shot of the back end of one I recently restored.
The two 2-pin headers go to a "eject" switch (for non-Mac use) and "in use" LED.
You talking the other floppy port header? I would presume that's for the daisy chain port.What about the second pin header? Has it ever been used on any Apple floppy drives?
Now that’s something I gotta try. Was also wondering would this add DB19 capabilities if connected to a floppy port say for instance on machines that don’t have a DB19?As others have mentioned, it's the connector board for the external floppy. @Johnnya101 @Nixontheknight The second floppy header actually connects to the external floppy cable (the cable that ultimately connects to the computer.) The female connector on the board is for daisy-chaining.
@jajan547 The little adapter board is still useful, though. It gives you real LED r/w status for any floppy drive. So if you stuff it somewhere between your floppy drive and your Mac's motherboard, you can route some LEDs to the front of your case and get real LED action. I did it on my IIci (fits perfectly under the drive cage.)
I think that might work.Now that’s something I gotta try. Was also wondering would this add DB19 capabilities if connected to a floppy port say for instance on machines that don’t have a DB19?
This is an easily reversible mod and I think it's slick on any system that isn't trying to look historically accurate... Hopefully a simpler version can be recreated so viable A9M0106 enclosures aren't needed. I was lucky to find a lot auction which included one ruined case and a second with internal plastic bits rattling around, but I'd feel bad making this permanent if I hadn't had such an opportunity.So if you stuff it somewhere between your floppy drive and your Mac's motherboard, you can route some LEDs to the front of your case and get real LED action. I did it on my IIci (fits perfectly under the drive cage.)
