WD HD in an LC 520?
I just got a 2.1 GB SCSI HD for my LC520(with 575mb in it) ...
I can boot to CD, but when I use disk tools on my drive, it lists it as incompatible.
It sees it fine. It lists it on ID 0. So there's no conflict...
Anyone know if there's a way to make it work? a certain jumper setting that I'm missing?
Thanks!
What OS you are running on it?
If it is System 7.5 - 8.0, you need to partition it to 2.0GB or less and format it.
If it is System 8.1, you should be be about to partition and format it fully.
The drive is 2.1 marketing gigs, which is 2.1 billion bytes. Since that's less than 2 computer gigabytes (which is 2,147,483,648 bytes), you'll be fine.
For the umpteenth time...
It's actually a little more complicated than this, and also a little simpler than you want to make it.
Unless the OP has found the original install media with 7.1 for a 575, then they are going to be running a version of Mac OS that will happily handle running on a 4-gig partition. Please stop making this harder than it has to be.
The situation with 8.1 is a little murkier than this too. You're oversimplifying this because a 68k Mac can't boot from an HFS+ partition, so if you had some kind of 68k Mac with a big disk (easy to do) and booting 8.1 (also easy to do) and you wanted to have an HFS+ partition, you'd still need to boot HFS.
To be honest, even if the machine was going to hit some kind of limit (it won't), then it might just be worth skipping the second 100-meg partition, but that's really an aesthetic thing and you could go in reverse and use, say, a 300-meg boot partition and the rest of the disk for data.
Good luck, my LC5xx brother.  Keep that 520 alive  :)
I've got a 520 around here I need to set up. I don't think I have them here, but I do have the original install media for mine. 7.1 for life! They're weird looking but charming machines.
I'm just stating my point, Cory. Nothing more.
Now, as I remember the 520 was the first of the AIOs with the 13in monitor and is closer in design to the Color Classic which is more like an LC II than the Color Classic II which is more like an LC III. It and the series that followed was bought by many schools here in NYC, which I took care of for many years until they upgraded to OSX machines around 2002.
According to the install CDs I have from the school districts I worked for, the System for the 520 is System 7.5. I believe that the 520 may be able to run System 7(.1) but that remains to be seen and that is opinion and conjecture on my part based on my experiences with them long ago.
Using both the "Hacked version" of HD Setup, LIDO, Silverlinging or other Hard Drive utility would be beneficial in partitioning and formatting a Non-Apple Hard Drive on a Mac. But I have seen WD Hard drives in Macs as far back as the late 80s with the Mac Plus along with Quantums, Segates and many others but not all were formattable with the standard Apple HD Setup. In the least, he, the OP, should use something other than Apple's HD Setup.
Now, stating from my experience and what I have observed, if one has a drive that is larger than 2.0GB and are using System 7 and HSF format, there will be problems. Again, stating from my experience and what I have observed, partitioning the drive to 2.0GB or less have solved such problems of having a larger than 2.0GB partition. If he is using OS 8.1, then this is a non-issue and there should be no problems with using a partition larger than 2.0GB. The question is, what system is being used on this drive?
Lets supposed that there is a 2.0GB limit. Lets just suppose that. Now lets do some math...
2.0GB in decimal is 2,000MB or 2,000,000KB or 2,000,000,000B.
2.0GB in binary is 2,048MB or  2,097,152KB or 2,147,483,648B.
2.1GB in decimal is 2,100MB or 2,100,000KB or 2,100,000,000B.
2.1GB in binary is 2,176MB or 2,228,224KB or 2,281,701,376B.
The question lies in this part - Is 2,147,483,648B (2.0GB in binary bytes) referred too as 2.1GB decimal? Marketing use this would be a deception on manufacturer and seller in selling an item that is less than advertised. But I have seen this ploy done before.
Now if the drive is actually a 2.0GB drive where 2,147,483,648B is referred to as 2.1GB, then there should be no problem in partitioning and formatting this drive fully under System 7. Right?
Now lets take a step further. If the drive is formatted fully under System 7 (which I have done on hard drives and other storage media as large as 8GB), and there are problems trying to copy files or installing a system to it, then it needs to be partitioned to 2.0GB or 2048MB or smaller. This is my proposal to get things working as from what I know. If it formats fine and it copies files fine and installs a system without partitioning, then my information is useless.
What I post is one possible solution out of the many other users have stated. Nothing more. But I take it further by putting in instructions and explaining why things might be happening, which many here do not do. Their statements of "Use the hacked version of HD Setup" is a partial answer because they do not explain how or where to get it as it is not on the Apple System Install CDs. And many times I seen "go to Macgarden.com to get such and such software" when it is in the past I noticed admins deleting such links and giving a warning that Macgarden is a software piracy site, but not as of lately. Yet when I post something about System 7 and HD partitions, you jump on my post.
Now, people here do not have to take my information I put up as fact, knowledge from experience or advisement. If members here find that another's information to work for them, then that is fine and I am glad that they were able to find a solution to their Mac problem(s) without my help. I am here to help out by stating what I know from old Macs and the experiences I have with them since 1986. And I'm not here to look for brownie points either, if somebody is able to solve an issue they have with their Mac with what I proposed then good for them. I'm not here to take credit from anyone even if my advice worked for them. Case in point: a certain member here had an issue with a CC and a 8GB SSD under System 7 which would partition and format in 2.0 slices but it did not work (files would not copy and a system could not install). I advised for him to shrink the partitions to 1.9GB, which he did and the problem was solved. Did I take credit for it? No. Did I brag about it? No. Did I jumped up and did a happy dance of victory?  Hell no.
I'm just here to share information, experience and knowledge. We can discuss what works and what does not work and why. That is what any forum is about. So lets enjoy the fruits of our labour, in this case - restoring old Macs to working condition.
Drive manufacturers use marketing (that is, decimal) gigabytes and terabytes. No drive manufacturer that I know of has ever used powers of two.
That's great. Can you stop now, please?
There isn't. Seriously, stop trying to bury your wrongness in irrelevant waffle. Nobody is buying it.
If the drive is formatted fully under System 7 / then it needs to be partitioned to 2.0GB or 2048MB or smaller.
No it fucking doesn't. For the last time, shut the hell up.
Because you are blatantly bullshitting. Give it up. Nobody is going to suddenly agree with you.
By the way, it's HFS not HSF.  If you can't get that right after *multiple* times it's been pointed out, why the hell do you expect anyone to pay one second's attention to the rest of your bullcrap?
<snip>
There's no fruits of this labor. You are making stuff up , and the rest of us have to follow you around and try to make sure nobody believes whatever it is you're posting.
To make things worse, you're using big words and technical terms to try to make it look like you're in a position of authority. You don't even know for sure what OSes will run on an LC520 or what machine it is (meanwhile, I literally have one in my house) and you don't appear to be willing to look it up.
We're all entitled to our opinions, but nobody is entitled to turn their opinion into a personal fact.
Plus, it's not even just that you have these opinions about system 7 -- you claim to have experience and knowledge as to what causes problems, but you don't ever appear to be willing to follow up with documentation about what you did. Perhaps if you did that, some of the rest of us could actually assist you in making larger disks work in your systems.
Now now, gentlemen....
Whatever those facts might be (though I, for one, have often found that 2.1GB drives are NOT usable in 68k hardware without further ado), back on planet earth, the WD drive is still probably best partitioned into a couple of 1GB drives. This is because of the limitations of HFS formatting on larger period drives, since otherwise much of the drive's capacity is wasted. The partioning and formatting can be done via a patched version of HD Setup, Lido, or Silverlining, but it would appear, not by means of the stock tools.
