Same issues here with 1.6.4 and Mac OS 8.0, 8.1 - the control panel fails to load. Ended up chucking 7.6.1 on mine and leaving it, however deleting the preferences file might help.I had my Houdini II installed in a Q950 (before the thing blew up) and although the card was recognized by 8.1 (I remember checking with a program called Slots that it was correctly identified), the control panel simply would not start (if I double clicked it, it would simply reset the Mac desktop... I tried 1.02, 1.6.4 and 2.1.7 with no avail. I did not check the CPU at the time (maybe it was also running too hot?). Could it be an OS incompatibility?
I don't recall seeing a jumper on the ones I've seen/bought. Where is it located?I have two 486/66 cards. One has a Jumper and works just great in all of my PM6100.
I have another 486/66 card that has no jumper and only works on my quadra700, on all PM6100 I do not get a bootscreen.
The 1.64 software (regardless if the main OS is 7.5.3 7.6.1 8.x) always stays a "PC is booting" what is wrong here?
I chanegd the PDS Adapter but that did not help. Are there some 486 cards that are not compatible with the PM6100?
Thx!
Crazy! Had you used the same cable as worked on the other one?Man! it was the cable! It's working now!
