Sonnet G3 233mhz accelerator and PM 6100 with HPV
So, I scored a 233mhz g3 PDS accelerator off of ebay, and it works.
This weekend I was testing this out with Mac OS 7.6.1 to see if there were issue.
I see that the extention is disabled if I plug my HPV card into the slot.
Does anyone know of a "hack" or way to force-enable it? I know that later/newer versions had this working
I have a Sonnet 266mhz card and HPV card used together in my 6100 with no issue.
do you have the correct metal frame to support the HPV card or is it resting all its weight on the G3? If the G3 card is carrying all the weight it may not have a good connection on the logic board and is disabling. Also, try cleaning all the contacts on both cards and both connectors.
