I recently picked up a performa 430 and performa monitor(M9101ll/B) for a great price, and am working on getting them both fixed up.
The 430 does power on and boot up, but the hdd is shot(no surprise), though the caps on the board began leaking which i have replacements for on the way. I also have some on the way for the psu too since they are known for being bad as well.
There's some noticeable rust on the metal plate that is attached to the top plastic cover of the case however, so my question is can i just remove that metal part and leave just the plastic case? The rust to be on both sides, so cleaning it will be quite a challenge. There's also some rust on the power supply housing as well as the rear db15 connector, would something like vinegar be sufficient to remove it? Any other suggestions for cleaning the rust off?
The db15 connector on the monitor is a total loss as it's so rusted parts crumbled in my fingers. Is there a place I can get a replacement cable for the monitor, or if not how feasible would i be to cut the old connector off and solder on a new db15 connector?
And one last question, there's empty solder pads for where the fpu socket would plug into, if i were to solder PLCC socket into that could i plug a 68882 into it?
