it's great and i love it. can't find any PDS ethernet cards, will those farallon cards that work in the performas work with this? what are my options for ethernet?
My understanding is that SE/30 only takes PDS cards designed for the SE/30. The non-compact Macs (plus the Color Classic) use the LC PDS standard (well, I'm not sure if it's an actual standard, but I believe these are mostly interchangeable with each other).
You'll want to make sure your card is specifically designed to work with the SE/30. It's also not compatible with PDS cards for the SE (which I have, and are even more rare)
SE/30 ethernet cards do seem to pop up fairly regularly on here, eBay, etc. But RaSCSI seems to be a great choice if you aren't set on going 100% authentic with it, haha
SE and SE/30 ethernet cards are not swappable, different PDS slots. Depending on how many compacts you have an external SCSI to ethernet is probably a good idea to have.
Both my SE/30's have ethernet but only one of my 3 SE's do so I have the SCSI to ethernet when I need it.
An ethernet card that happens to have a PDS passthrough and a IIci-type cache slot that takes various 030 and 040 accelerators.
Sold all my stock for now though.
