Hi there,
I have an LC 475 that I try to use with VGA on a small HD LCD TV. Sadly, the LC 475 send the video signal at 67Hz and the LCD TV does not support this mode. I use a VGA2HDMI converter. I know it works, as I'm also using the same setup on my Beige G3 and can use resolution up to 1024x768 at 75Hz without any issue. On the G3, I tried also the 640x768 at 67 Hz, and effectively, the TV was unable to display anything.
The LC475 runs 7.5.3, and in the Monitor control panel I only have the 640x768 at 67 Hz available to choose from.
Is there a way to force the LC to offer any other resolution or even simply different refresh rate?
Thank you
Thank you
