Radius SE TPD card drivers
apm
Does anyone have drivers for the Radius display cards for the Plus and SE?
I've been working on getting a Radius Two-Page Display card for the SE back up and running from a state where it was hanging the machine. See this TC thread:
SE PDS card ROMs
Now I'm getting somewhere with the hardware but stuck without the drivers. All I can find is a long-dead Mac Driver Museum link and some newer versions of RadiusWare that I think don't support the SE anyway. Any suggestions appreciated.
Here's the info on the missing Mac Driver Museum download:
Radius.sea.hqx          *** RadiusWare Disks for Mac Classic / SE / Plus
                            This is a complete copy of RadiusWare for the
                            Mac Classic, Mac SE, and Mac Plus.  It
                            includes an installer program that will
                            determine what files your system will need to
                            work with your installed Radius Products.
                            It includes the following software:
                                  RadiusWare CDEV v.2.0
                                  Classic / SE / Plus Display CDEV v.4.1
                                  RadiusMATH v. 1.5
                                  Radius Accelerator v. 2.9
                                  Responder v. 2.0.2
                                  AppleTalk v. 56.0
                            This software is to be used for the following
                            Radius Products:
                            Accelerator 16 and 25 for the Mac SE
                            Full Page Display Interfaces for Mac
                            Classic, Mac SE and Mac Plus
                            Two Page Display Interfaces
                            for the Mac SE.
                            It also provides System 7 compatibility for
                            these products in conjunction with the proper
                            version of ROMS.
It sounds like anyone with the RadiusWare driver disk for any of the products mentioned should have the whole enchilada. [:)] ]'>
Couldn't find the RadiusWare floppy, but I found all the documentation for the Radius16 that went down the storage room whirlpool inside its SE ten years ago.
On a HDD from well before that, in the driver downloads folder, I found the Installer set for the Radius FPD, my Eleanor going on almost three decades now, email sent.
OK, searched around and wound up right back here!
Now I'm the one in need Radius.sea.hqx for my new SE/Radius16/TPD setup. Anybody got a link? I've got that TAR file and not one single clue how to break into it.
Did you ever get your card working, apm? Mine has the v4.4 ROMs you were looking for and is showing some signs of life.
Thanks for helping me out with the Accelerator drivers. It's strange that the Radius.sea.hqx file listed between those two went missing from the TAR files. Still looking for the FPD/TPD card drivers! Anybody got that file? :-/
It is a 5 years old topic, I know - but the hopes...
I have many Mac SEs and find a Radius Two Page Display few weeks ago (February 2022) with the ROM version 3.3!
Does any of you (still) have drivers for it? I am searching the Radius.sea.hqx and the CL_SEA_PL.sea.hqx files.
In 2022 March on the https://vintageapple.org/macdrivers/radiuscards.html only the discription exists, the files behind the link are disappeared, because they're pointing to a nonexisting host : www.macdrivermuseum.com. Macintosh Repository and Macintosh Garden have the same archives but they are also for ROM version 4.x
or
Does anybody has the ROM files for 4.1 (or 4.4) versions?
I am hoping @Trash80toHP_Mini still have somewhere something... would be great!
Thank you.
Yep, something, somewhere. ;) From your ROM questions, I assume you meant you found the interface card, not the display? Couldn't find the thread in time available this morning, but you'll be looking for a thread with a title something like: Radius SE TPD up and running on an LCD no less.
Back again tonight, never did hit the post button. :rolleyes:
Links to most of the pictures in that thread were lost in the mess the software upgrade crash caused. The links open, but apparently connected to randomly selected photos? Drivers you found (LINK?) for later ROM versions of card ought to be backward compatible, that's the Radius way based on my experience, so give it a shot.
Most everything else, including this ASCII art representation of "Trident" cable adaption description. I'll have to re-document a Readers Digested version of my research results a new thread when I get the chance, meanwhile here's a Rev.2 version:
_______
\______/ HD15F - Soldertail Connector like this DE9 Connector
\ | / Red, Green and Blue wires: color coding optional 🤪
._
|_| Female end of a breadboard type jumper cable below.
Twist/solder four wires together into trident form factor, heat shrink connection and solder RGB wires to RGB solder cups matched to HD15F VGA pinout:
have fun,
jt
If you can't get a properly sync'd image, take a look at this thread:
Yes, this is the interface card. The ROM labels are:
for the LO chip:for the HI chip:
Code:
©1988 RADIUS INC
     SE TPD
LO 297-0049-A
  V 3.3 256K
Code:
©1988 RADIUS INC
     SE TPD
HI 297-0050-A
  V 3.3 256K
I will dump both ROM content for archiving.
The previously mentioned drivers are in the macintoshrepository.org and macintoshgarden.org. The contet listing is from https://vintageapple.org/macdrivers/radiuscards.html.
Everything what I find is for the ROM v4.x versions, nothing for earlier, especially for ROM v3.3.
Nice! I was just typing up elaboration on above, but see you don't really need it yourself. Bolt HD15F up to that DE9 cutout. :)
Have you tested those drivers for backward compatibility yet?
_______________________________________________________ morning musings:
There are a lot of options available for the breakout panel. Do we have a dedicated thread yet for that kind of thing for SE, SE/30 & IIsi applications?
Should I start a new one maybe? This is is off topic here I think.
I probably have the largest collection of thais kinda crap on hand to kick it off? If someone wants to do a PCB layout for a baseline VGA connector board to bolt up to the back that would be great. Ground plane RFI shielding overall connected to bolt holes would be about perfect.
Put HD15F connector on one end along with mounting hole for WiFi antenna would be just about perfect. Remainder of board could be drilled out for any other connections desired . . .
edit: hrmmm, is there a panel mount SD card extender cable available? Model for printable panel mounting of available extender cable?
Have you tried those drivers yet?
Yes. Any of the RadiusWare or the Classic/SE/+ Display or anything what I find did not do anything on System 6.0.8. Basically if I dropped them into the System Folder, after reboot they crashed the whole system.
On System 7.0.1 the system hangs on boot "inside" the "Welcome to Macintosh" window.
That's why I think my ROM v3.3 is not compatible with the RadiusWare developed for the ROM 4.1 or ROM 4.4...
