128k just died :(
mloret
I was testing a drive on my Mac 128k and it randomly cut out. Now It won't turn on and it's making a strange clicking noise. Can someone tell me what has gone wrong here? I'm pretty sure it's a power issue on the analog board (has been recapped).
M
I would say you have a short somewhere. Remove the drive you were testing and see if that was it, look for a dropper screw, broken solder joints, shorted diodes etc.
What @Unknown_K says. Was the drive a manual inject 1.4MB drive, perchance? Tried subsituting the manual inject floppy that's currently in my Centris 650 into my Plus, so I could see if I could get the computer to boot a floppy. Drive draws too much power. No chime, flupping sound from the analog board. Flipped the switch off, unplugged the drive, turned the switch back on. Chime and video. Connected the original drive with its stripped eject gear. Turned it on. Chime, video, then a very angry eject motor.
I unplugged the drive I was testing and the same. I’ll unplug everything and test.
Hmmm, ok. It's possible that you might've overloaded some circuitry on the analog board and something failed. Usually, if the flyback transformer dies, the computer will still boot, it just won't show anything on the monitor.
Okay would that something be a cap?
Tants fail shorted, aluminum analytics fail open-ish (way out of spec).
A flyback can short out so check it to ground.
Sounds like something is tripping the PS which tries to start up again hence the clicking. Old supplies could have many faults but I figure you overloaded something and it shorted or cracked something while messing inside (happens).
I think the clicking type noise is coming from the display.
EDIT: I take it back. I can't tell where the damn clicking is coming from but the different components don't appear to be getting power. I tried different outlets and power cords. Listen...does this ring a bell to anyone?View attachment IMG_3432.mov
It was okay and then cut out and never came back.
Because something went hard short. its going to be one of two things. Either the horizontal output transistor shorted due to the flyback, or, one of the secondary rectifier diodes on the output of the power supply went hard short.
Im learning how to work on these the hard way.
Do you happen to know the location if these? This is all pretty new to me and I learning the hard way. :/
And what’s a hard short?
Might be time to travel down the youtube rabbit hole and watch some videos of others working on/teaching how to troubleshoot electronics, and these things.
But a hard short is basically anything on a power supply rail circuit that has a near 0 resistance to ground when its not supposed to, aka, shorted. short circuit.
Roger that. Most of what I know, albeit limited, I learned in the rabbit hole.:unsure:
I just took everything apart to isolate the problem. It's definitely on the analog board. I checked the joints and everything seemed okay. I reflowed a couple that looked shady but still the same thing. With everything disconnected, I plug the analog board in and it still makes that ticking sound. It's difficult to tell where it's coming from, but I think it's transformer labeled T3 (Astec 157-0025-A). If this is where the ticking is coming from, does that mean the transformer needs replacing (caps already done) OR is that a symptom of the short somewhere else on the board?
