Original BMUG Disks
olePigeon
68040
I recently acquired nearly 40 original BMUG disks. I'm sure the contents of these are well preserved in CD form when they released those compilation CDs. But it's fun having the original floppy disks. I hope to image them soon. These look to be some early disks.
Nice find! The CDs would usually contain the latest versions of software, and also wouldn't necessarily include older obsolete items. (Especially since at least some of these are 400k disks -- it was unusual for CD compilations to include 128k/512k software.) So would definitely like to see these imaged.
Unfortunately the disks have mold in them and it gummed up my floppy drive with the first disk. I'm 3D printing a gadget that should help me clean them. I'm just hoping I didn't irreparably damage my LC's floppy drive.
That's terrible! I often worry about that when getting floppy disks.
I do have a few of the BMUG CD-ROM collections that they published. I'll have to see about uploading them to the Macintosh Garden.
As far as I can tell, all of these disks are completely fubar. They permanently took down 2 of my floppy drives, even after I thoroughly cleaned the disks. Literally brought the two drives to a screeching halt. I was able to get one of the drives to work again after liberal cleaning of the heads. Tested it with known working disks. Worked fine. Decided to give one more disk a try after a nice clean, and ... screeeeeeeeeeech plop. :( No amount of cleaning the heads has brought back those two drives.
So I'm not going to risk trying any more of these disks, unfortunately.
I'm hoping they've been imaged by someone else somewhere. I could transfer the labels to some new disks.
What a sorry story! Those floppy drives are worth more than the disks. The good thing is if you get some good head assemblies, you can get them working.
That's awful. Not worth the sacrifice of floppy drives to read this data. How do the floppies look? (Photos?) Wondering what I should watch out for.
Have you tried IPA and a qtip on the disk surface itself? It’s a common solution for reading old commodore disks that won’t read.
I've found that sometimes 70% isopropyl won't work for some stuff - I have to use 99%; because what the other 30% is made of in 70% isopropyl is water; and some stuff is very hydrophobic.
91% is just fine. I use 99% only because at the start of the pandemic, when everyone was raiding CVS like mad, there were 5 gallon jugs of 99% on Amazon for a reasonable price!
They had 2-for-1 at my local drug store for 91%, so I grabbed that.
I'm going to clean my dead floppy drives anyway to make sure they don't damage good disks, and then use one of them for "screech testing" on unknown floppies. If it doesn't screech on the bad drive, then I can safely move the floppy to my good drive and attempt to read it.
I mentioned in a PM that I'm going to take some autopsy pictures of the disks. The disk is a dull brown and not the shiny black as compared to another floppy disk. I don't know if this is just a difference in manufacturing, or if it's discoloration from some sort of degradation. If it's degradation, then it could be an easy-to-see visual clue if a disk might hurt your floppy drive.
Judging by the symptoms you describe, it could be a form of what's called sticky-shed syndrome. Sticky-shed syndrome is a common problem with older audio tapes where the adhesive bonding the oxide layer to the substrate deteriorates and takes on moisture from its environment. The two main symptoms are shedding copious amounts of oxide on the heads and in the tape transport, and stickiness caused by the deterioration of the adhesive (which can cause screeching and squeaking as the affected tape moves through the transport).
A temporary cure is to drive the moisture out by baking at a relatively low temperature for a period of time, thus allowing the tape to playback normally for archival purposes (it's useless beyond that).
I'm not sure if it can affect floppy disks, but you could try baking one and see what happens?
c
I wouldn't bother trying them again, it's not worth the risk to damage more drives. I suspect this is what has happened to a lot of my drives, the ones that mechanically seem to work fine but just won't read disks properly no matter what.
Has anyone had a good experience with "new" floppy disks? Are there any that can be trusted?
So, the bad one is on the left and a "good" one is on the right (bad sectors, but whatever.) You can really see the difference in color. The diffusion is caused by whatever that crud is on it.
Closeup of a bad disk. You can see all the crud. I thought I had thoroughly cleaned this with 91% IPA. But it's clearly still all gunky. You can also see the circles where the head scraped.
Closeup of a good one.
These were in someplace with very high moisture. Some of these disks are dated 1989, but the label peeled right off like it was new.
Here's a closeup of a disk I had attempted to clean with a q-tip and 91% IPA. There was no saving these disks. Whatever is on these, it's on for good. I wonder if the magnetic stuff has separated from the plastic, and all the IPA does is wash it about without actually cleaning anything.
Out of curiosity, I'm going to try soap & warm water real quick.
Soap & warm water did much better, but there are still splotches here and there. These disks are unrecoverable. However, the soap & warm water has given me a little bit of hope for my floppy drives. I'm going to try cleaning them with warm water & soap, then a nice second clean with IPA. Maybe I can bring one or both back to life.
I get mine from floppy disk.com or whatever the site is. Think I got the used 800k 50 pack last time. I'd trust them over other sites or places. The disks I got all seem to work and are all sony branded.
Hazzah! I got both my drives working again. The soapy water took off dark black dots that had appeared after using the bad disks (not the black line, but some dark dots around it) on the top and bottom heads. I couldn't clean them off with IPA, so I assumed they were permanently damaged. But warm soapy water cleaned the dark dots off with just a few passes. Did a final clean with IPA. This was a successful experiment. Edit: I should have taken some before & after pictures of the black dots.
Phew!
Is there a reason not to use soapy water on the heads for general cleaning, followed up by IPA? I can understand perhaps soap film drying on it, but that's why I'd follow up with an IPA clean.
