Hey everyone!
I’ve encountered very strange behavior with regards to these pizza box Macs.
It started out when I was building my own 60ns VRAM SIMMs and I noticed a performance boost. I was seeing a ~15% performance increase when using 60ns VRAM in a 33mhz overclocked LC475 when compared to 70/80ns VRAM.
I had reached out to Silicon Insider to ask whether he had any 60ns VRAM chips and whether he saw any performance gain from using them and he did some significant testing on a 33mhz LC475. He got the same results no matter if 60 or 80ns VRAM were used, and they were similar results to my “higher” results from using 60ns. Meaning for some reason my OC 475 using 70 and 80ns VRAM was returning SLOWER results.
I’ve thought long and hard how this could be possible.
I have built more than 10 of the 60ns VRAM SIMMs and have tried several to verify. I have tried these in 3 different overclocked 475 machines, with nearly identical results.
All of my 475 that I’m testing on have been recapped with solid tantalum caps. Some have higher voltage caps, and some have the same voltage as the stock ones.
I purchased another 475 so I could test against the stock electrolytic caps and compare. I got the same results as vs when I recapped that same board.
Then I discovered a strange result: when J18 is installed (to identify it as a Quadra 605) I got ~15% performance degradation on the 33mhz overclock. I did not try that before overclocking, sadly.
Nearly all of the variances in speed occur ONLY in 16bit color tests. The 8bit color tests are always within margins of each other.
I just don’t understand what’s going on here.
To add to this mess of strange results, I have more!
Last night I was testing batches of 68040 CPUs I have sourced on eBay. Yes, I’m crazy, but I have obtained 10x full 68040 CPUs marked 40mhz from several sellers. Looking at the silkscreen they appear to be authentic and not relabeled.
I have a variety of masks and revisions, including XC and MC parts, two of which are 57um 2006 manufacture (0K63H, which is just prior to the infamous L88M everyone seeks).
The worst video benchmark score I saw was with the MC68040RC40A with mask 0K63H.
I tested using two different logic boards but consistently keeping things the same. Meaning I tried the same logic board, RAM and VRAM with the CPUs, then another different logic board with another set of RAM and VRAM on that board, with all of the CPUs, and then switching RAM and VRAM between the two boards. Always the same results.
So, it seems that I’m seeing variations in video benchmarks when using different CPUs.
Is there anyone here who can assist me in validating my tests? Someone who has a 475 board that is overclocked to 33mhz, that has a variety of 68040 and 68LC040 chips and a few different speeds of VRAM to independently verify my crazy results? I see little variation when using the stock 25mhz board speed.
If someone is willing to test on at least 2 boards and with at least 2-3 different combinations of CPU and needs a pair of 60ns VRAM I would be willing to ship some out to help nail down what is going on here.
I’d also love to hear the theories and thoughts behind the J18/Quadra 605 slowdown I saw at 33mhz overclock. If you have a 33mhz overclocked 475 and can run a 16bit video benchmark (and 8bit for good luck as well) with and without the jumper I’d love to hear the results.
I also used a variety of PSUs just to ensure for some reason the power supply wasn’t playing a role in the variations. I’m trying to be as scientific as possible.
Your help and support on this is greatly appreciated and I feel it would benefit the community to validate what I’m seeing.
