RaSCSI: install DaynaPORT drivers without floppy disk?
I had to remake my RaSCSI install because the SD card I was using died because of the heat generated in my Macintosh Classic, but I can't for the life of me figure out how to install the DaynaPORT drivers without a disk without it failing to recognize the digital disk and asking for the physical one (which I don't have any). How would I be able to do this?
Ok guts, before I go crazy, I have the RaSCSI working great as a disk/ multiple disks, but the daynaport is giving me hell
I have created 2 disks with the network tools and Daynaport installers in raw/40MB disk files. I named them after the floppies the installers expected and I have installed everything pretty well
At this point I can ping the RaSCSI from the SE, and I can ping the SE from terminal on the RaSCSI. But if I try actual traffic, even pings, only outgoing works. Nothing makes it back to the SE. I can run topdump and see the pings headed out, and even the replies sent toward the SE, but it won't receive packets. Anyone else run into this?
