If you have 6-8 megabytes of RAM in your cmassic Mac, here's why you should use OpenTransport instead of MacTCP...
On my Quadra 650, with 40 megabytes of RAM, System 7.5.3R2, using the built-in AAUI Ethernet interface.
Rrunning MacTCP 2.0.6, when downloading a multi-megabyte file from a local HTTP server on my LAN, I get a measly 40 kilobytes/sec.
On the _exact same machine_, with OpenTransport 1.1.2 installed and in use, downloading the exact same multi-megabyte file, the download speed is stable at about 115-120 kilobytes/sec, which is nearly three times the throughput. I also tried with OpenTransport 1.3, with the same results.
