I would say it's the remains of some component that overheated and burned out, but without more information, it's hard to say for sure.What's the black mark on the heatsink?
Sorry to hear about that. If you need a new motherboard, there's one on ebay. https://www.ebay.com/itm/3843029899...VkHk2NxpMfTCfQ%3D%3D|ampid:PL_CLK|clp:2334524View attachment 35104View attachment 35105View attachment 35106View attachment 35107View attachment 35108
i'm at a loss of words and mourn the death of my dual core 2.3GHz G5. i wonder if someone else has experienced an issue like this? this computer was stressed to the bone it seems... it had the checkstop LED come on too
the black mark is the only remains of the heatsink's original black color. the heatsink is aluminum and it had discolored. the copper heatsink where the chipset looks very worn out and is discolored too.What's the black mark on the heatsink?
Judging by the deeper copper colour near the thermal paste (on the heatsink), it looks like it was running very hot.
i haven't seen any burnt out components.I would say it's the remains of some component that overheated and burned out, but without more information, it's hard to say for sure.
c
i'm not sure what it is either, but looking at ONE other photo i found of this chip on house of moth, it appears to look very worn out. there are small "bubbles" on the die of my chip. what i can say is that the epoxy is NOT looking good.I don't entirely understand what I'm looking at here: is that damage to the top of the chip?
the northbridge uses that large heatsink and the southbridge uses the small aluminum one. my question is how did the southbridge run so hot to the point it managed to discolor the heatsink??I guess those are chipset controllers with small heatsinks needing proper airflow to stay cool. On PC motherboards they would have a large heatsink and a cooling fan or heat pipe.
could have. all i can say is that the board is toast and the CPU might be too. i just want to reach out to ensure that i'm not alone and find out if someone else had this same issue too. some people did report CHECKSTOP lights but they said their CPU had simply overheated and i've only seen posts about the light coming on in the G5 quad, which i do NOT have.I guess it overheated?
seeing as how these get hot and use some crappy lead-free solder, i'm sure somehow those connections cracked and caused the chip to fail. i'll get a new motherboard when i have money to do so.Those chips have BGA connections and if one or more crack you get hot spots that eventually kill the chip.
