I have a LaserWriter II that I've been working on today. It wasn't picking up paper at all, but after putting a few rubber bands round the pickup roller it is now picking up paper with a 50% success ratio! Not great, but I'll take it for now! I'm able to print the service test page, which is great.
The main issue is that, when powered on, after a couple of minutes, it flashes the two red lights (paper out and paper jam). This means a fuser issue, which is also confirmed when I put in a IIg board, jumper pins 4 and 22 of the serial port to put it into diagnostic mode, and it also shows a fuser error.
I've gone through the troubleshooting steps of Table D on page 108 of https://vintageapple.org/laserwriter/pdf/Apple_Service_Guide_LaserWriter_Printers_January_1992.pdf, and the fuser checks out okay. I've also replaced it with a spare which also measures okay, and I still have the same issue.
The last step in that table is "Replace the power supply block", so I'm guessing that at 31 years old, the PSU just isn't able to supply the current needed by the fuser any more. Obviously replacements are almost non-existent these days (while there are a couple of 110v ones on ebay, there aren't any 240v ones), and any NOS ones might have the same issue. So I'm thinking I probably need to recap it.
Before I attempt this, I wanted to see if anyone else has had this issue? Did you fix it? Did you recap the psu?
