Flashing a 7800gs for an MDD
Hi guys,
I have this XFX 7800gs 256mb AGP which I want to flash to make it work in my 1.25ghz DP MDD. It has the correct chip revision, but it is quite an obscure card and I have never seen anybody else mention it. Can I just use one of the modded roms from The Mac Elite?
More then likely you will need a bigger flash ROM chip on the card for the code to fit. The 7800gs will work as I am pretty sure I have one in my G5 1.6ghz single CPU machine somebody else had flashed.
I know that I need a bigger ROM for the original mac ROM, but on the website are three modded roms which will fit on the original ROM chip, it's just that I'm not sure which one I need to flash.
