So, I was going to ask for recommendations for a display for a Blue & White G3. I booted it up so I could see what resolution I ran it at so I could get a display that would work at that same resolution. Except that I booted it up, and nothing shows up on the display. I know it's booting. I know it finishes booting. And I can shut it down by pressing the power button on the keyboard and hitting "Return" to confirm shutdown. Tried turning it on and off, cutting off power, letting it sit both powered and unpowered before powering up again, etc. Nothing.
Display works. Cables have good connections. Rage card seated inside the G3 properly. But no go.
Worked last time I booted it up which has been a month or so or more. Don't remember for certain.
Any ideas? Bad Rage card? Something else?
Thanks!
Thanks!
