EPROM Copy of Macintosh 512K ROMS 64KB
Sadly ill never have time, but I wanted to hack a Plus to run a Superdrive FDHD. Patching the .Sony driver from an SE into the Plus ROMs, and swapping the IWM.
That's a really interesting idea. Do you know offhand if the SWIM is pin-compatible with the IWM? I think it's not, so some kind of adapter board would be needed.
It's a socketed replacement in the SE and Mac II. i.e., they sold 800K floppy equipped IIs and SEs which were later upgradeable to 1.44 floppy operation by swapping the IWM for a SWIM and changing the ROM chips.
That suggests that the two are pin compatible, unless the SWIM has more pins and the two Macs were built with a longer socket with upgrades in mind, but that seems unlikely.
As I remember, the SIWM and IWM chips are same size and same pin outs. They should fit the Plus without problems or modifications. It is the ROMs that determine how to read a disk from the S\IWM.
The question is - do you lose the ability to read 400K MFS disks and are stuck with 800K/1.4M HSF disks?
No, the SWIM is capable of working with 400k drives in addition to 800k/1.44MB.
And the ability to work with MFS is somewhat dependent on the SSW (SSW 6 or earlier is best for MFS compatibility).
c
I cant recall if the Plus and SE are identical, but I think they are. I know SWIM and IWM can be swapped around in the SE. and if I am not mistaking, the SE carried the same chip as the Plus did.
So, in theory, swapping for a SWIM And doing the necessary ROM changes it would work fine.
