Mac LC and DB15 to VGA adapter problem...
dragon_x
Hello all.  this is my first forum post.  My friend and I are trying to bring the Macintosh LC back to life.  the capacitors in the power supply and those responsible for the power supply on the motherboard have been replaced.  The Macintosh wakes up, a distinctive sound is heard after it is turned on.  however, we have a problem.  no stable image on the external monitor.  we are building our own adapter from db15 to VGA because currently in Poland or the other near placed countries we can not buy a sensible adapter anywhere.  we tried a few patterns but to no avail.  we get either unstable image without synchronization or uniformly white or black.  we checked it on several monitors and a projector.  I did not find a solution on the forum, so I am asking for help.
thank You and greetings
What arrangement of wires has been the most successful to date? How much VRAM does the LC have?
Hi, thank you for your answer,
We dont know how much VRAM does the LC have but I think that 256KB. How to check it? We have VRAM as on the picture.
We used this wires arrangement as showed on the picture.
Projector shows only right resolution information as 640x480 pixels at 60Hz.
an original adapter will be your best solution.
Those can be found on Ebay pretty easily and probably not for much money.
I will try another LCD first, much are not able to play fine with resolutions supplied.
I know that original will be best solution, but waiting time for delivery is very long, aprox. october-january....
We wanna tray to make adapter by ourselves.
We checked this on other monitor and results was similar.
Are you sure the Logic board is ok ?
you mentioned some capacitors have been replaced, not all of them ?
of course we're not sure but some time ago a colleague ran it in connection with the crt multiscan monitor, which he had access to and the Mac was working.  capacitors in the power supply and three on the motherboard responsible for the power supply have been replaced.  after turning on, you can hear the characteristic sound of the Mac booting up.
The LC has a lot of capacitors in the Logic board, only replacing some and leaving the others can be your issue.
Again, is not really the capacitor, but more the fluid leaking all around.
Was the board washed or cleaned ?
the computer is at my friend's.  we know that we need to replace all of them, but my friend is afraid to solder smd.  the motherboard was cleaned somehow for sure.  there is a chance that the computer will come to me soon and then I plan to replace all the capacitors and clean it properly.  however, as I wrote earlier, LC worked with a multisync monitor.
Well, in the Logic board area, all capacitors are smd.
So don’t see really what capacitors have been changed or not.
You are lucky enough the board chimed or displayed  anything, many doesn’t work anymore, even with new caps around.
The right way may be find apple monitor for this Mac and check. But It is hard to find someone near with that monitor.
i wonder how to check motherboard ...
three caps was replaced for sure by my friend.
The good news is that mac react for instert floppy disk. Mac try to read disk and put it out. For now we dont have any bootable system disk. We are searching for a solution how to make it on windows 10.
The LC has a high density floppy drive, so you can make a boot disc on a PC using a raw disk image.  Not sure off the top of my head how you'd do it on Windows, but it should definitely work.
The Macs of that particular vintage are rather finicky as far as monitors go.
I have a 19" monitor that works well with an adapter on my LC475 but not on my IIsi. Other monitors (even 19" ones) play nicely with the IIsi.
The original LC and the IIsi came out at about the same time. Just a thought.
So I need to be a little lucky to adjust the monitor? Currently, Mac is with a friend. I hope he will be with me soon. I have a few monitors, including the old LG 17 "LCD, maybe it can handle it
