Hi.
Got a Powerbook 180 and it is not showing anything on the screen:
I've searched in the forum and I've found this user with the same issue:
I've also read that it may be an issue with bad capacitors and I have seen some people replacing the caps in other Powerbooks of the 100s series (nothing on the 180). I have disassembled the display and this one doesn't look like the ones I've seen that people fix, I can't find the capacitors
I have checked the cables for continuity and everything seems fine.
Any ideas??
Thanks
Any ideas??
Thanks
