Well, now that I have all the kinks worked out of my SE itself, I am trying to get the network card to work correctly. I have it connected via a normal Cat5 cable to my AirPort router. My iMac G4 and PowerTower Pro work fine with the AirPort. I have installed the Asante software, and EtherTalk shows up as "Alternate Ethernet in the Network control panel under System 7.1. I can select it, no issue. I have run Asante Troubleshooting, and the hardware tests verify that the card is working. The orange status light is constantly lit up on the daughter card, and the green access light blinks constantly. I have selected TPL to enable Linking via 10Base-T mode. The green connection status light on the AirPort ethernet jack does NOT light up, indicating no active connection. I have a feeling that there is some hardware incompatibility with the AirPort being so new. I really don't have much experience working out the intricacies of these networking issues so I could really use some guidance here.
