Hey guys,
I am repairing a macintosh classic and cannot get the sound to work.
Steps taken to resolve the issue:
1. recapped both the logic board and analog board. This fixed some display issues I was having. The Macintosh boots off of the rom just fine and all other functions appear to work. When recapping the logic board there was some corrosion of the pads but I was able to clean the dirty pads and revive them pretty well.
2. cleaned the logic board with 99% isopropyl alcohol
2. adjusted the voltage pot and have +12.1v on the 12v rail and +4.99v on the 5v rail
3. measured the resistance across the speaker and got 62.1 ohms which seems to indicate the speaker itself is working. (the speaker is rated at 63 ohms)
I have attached photos of the analog board and the logic board below. I am really scratching my head on this problem. I get no sound whatsoever. Maybe the sound chip itself is bad? Although, I have heard this rarely goes bad and if it does it usually causes other issues as it is tied in with the reset circuit. At this point, I am pretty sure I have read every other forum post on this issue and I still cannot seem to solve this problem.
