There's a design for it on Thingiverse. I've done it, not the orientation they told you to print it, but more economically (printing it like they say produces support structure waste), and worked fine until I took it out :/ then one of the legs broke. Might be a good candidate for nylon or PETG vs PLA filament.Has anyone made one?
I think we’ve all done that at least once. What version do you need? I have injection molded clear ones for the SE series but I might have some used ones for the Mac II floating around. I’ve found the 3d printed buttons to be weak.Has anyone made one?
A switch may have been broken while cracking a compact mac open....
Asking for a friend....
Definitely the downsides to FDM printed stuff—at that scale it's pretty brittle. I've been doing some stuff for 6" figurines and it's quite fragile. Has anyone tried a resin/UV printed version to see if it's more resilient?I’ve found the 3d printed buttons to be weak.
Resin is quite a bit more resilient though it can be brittle. I would say SLA is superior to FDM. Though the costs are typically higher. Seems to be a trade off no matter what is chosen.Definitely the downsides to FDM printed stuff—at that scale it's pretty brittle. I've been doing some stuff for 6" figurines and it's quite fragile. Has anyone tried the resin/UV version to see if it's more resilient?
I don't think it is too far off. I think within the next 10 years or so we will be there. I think that will mean some really amazing products that people do. Sadly, it will be nearly impossible to get perfectly transparent prints without post processing. That was something I discovered the hard way with various projects. I will never treat any transparent plastic, even injection molded, as being "cheap" simply because it is plastic. I just hope that the next generation is able to use all the amazing tools out there to create really cool stuff.it is not really there yet for replacing injection molded parts.
