So... I've got this PowerMac 4400/200 that I can't seem to get working. I've tested what I can (RAM, HDD and CD-ROM drive) and confirmed these parts work. I've measured each and every output of the PSU and they check out. I've replaced the PRAM battery too (although it's just a battery holder with 3 AA batteries).
First of all it chimes. However it only does so after I manually turn on the PSU and let it run for a minute like that. I suspect funky capacitors somewhere... but all the ones I can see are surface-mounted and I only have a soldering iron.
Problem is, I highly doubt the chime means anything at this point. It chimes with no RAM installed, it chimes with no RAM and no VRAM DIMM... no beeps or anything. I can hear the HDD seeking when I power it on and everything is plugged in as it should be, which is something, I guess.
Only apparent damage I've seen is one of the motherboard support studs is rusted through, some connectors (speaker, power switch, PRAM battery) are ever so slightly green and there's a hell of a lot of flux residue in the PSU board. I'd love to just throw in a new motherboard and forget about it, but I can't seem to find any (only complete units).
Where do I go from here? How can I troubleshoot it further?
