Acquired a second TAM unit, and this one really does not look so good:
But as they say, it’s what’s on the inside that counts, and what’s on the inside is:
- A Sonnet G3/500 accelerator
- A Sonnet Tango USB/FireWire PCI card
- An Ethernet Comm II card
- Plenty of RAM
- A fan?
I wasn’t really sure about the fan. I took it off to have a look, and it certainly doesn’t seem to be standard for the G3 card. I can’t imagine it would get very good airflow in that position either, and it was a bit hard to fit the back of the unit on. I wasn’t sure where the power was coming from, but I investigated further and…
…and I’m still not sure where the power is coming from. The previous owner must have gone through a fair bit of effort to get that fan in there. Actually, when running off a G3 card, is there any reason the fan over the original CPU needs to run anymore? The easiest power source would have been the existing fan header, I’d think.
I was missing the keyboard on my TAM, and I also managed to find a replacement. For some reason, the ADB cable from the keyboard was severed about a centimeter from the base, so the keyboard was exhibited as “not usable, for parts”. But! There are still two perfectly good ports on the keyboard, and all ports are created equal in ADB. I opened up the keyboard, cut out what was left of the original cable, and hooked up one of the “downstream” ports. Works fine!
Eventually I’ll probably solder on a replacement, but until I find a satisfactory donor cable, this works fine.
Lastly:
