Couldn't get that program to install despite following the instructions.
Bob says:
"In 9 I guess you are talking about. I never used the Apple Monitors so I never had the problem. If it was a non Apple monitor I would tell you to unhook and rehook up the display. If the cable that attaches the displays doesn't read the cable you get limited. Zapping the PRAM (command option p and r keys held down at startup for 3 chimes) tell the computer to look at what It is connected to like it was the first time. If that doesn't help there is a program on the Kitchen Sink for 9 in the Video Drivers called Super Res. It allows forced resolutions that are not normally listed."
I'm going to try zapping the PRAM. Should have been the first thing i tried really....lol
Bob says:
