I was using my SE/30 today when a "lightning bolt" shot down my screen and then it went blank. I turned it off and back on again but all I get is the fan - no boot chime. I'm getting 5.0V at the external floppy port, so I'm assuming this is an analog board issue. The Dead Mac Scrolls confirms this, and I've tested the barrel rectifier at CR2 and the transistor at Q2 which seem good. It looks like the next step is replacing the flyback transformer.
Should I do this or replace the capacitors on the analog board next? If I need a flyback where can I get one?
Thanks in advance!
Thanks in advance!
