Hello all,
When I bought my Centris 650 a few months back, I also bought an AAUI adapter so I could hook it up to the internet as well as transfer files with my OS 9 machines if I needed to do that. The adpater, which was NIB when I got it, worked fine for a while, but I think there must be a short in the cable that runs from the box to the Mac because the last time I used it I had to bend the adapter's cable and position the box a certain way otherwise I wouldn't get any signal. So I am now debating whether I should buy another adapter box or buy a Nubus card with an RJ45 port on it? All three of my Nubus slots are empty and the only other card I considered getting was maybe a graphics card at some point. On the other hand, another AAUI to RJ45 adapter box would be cheaper and not require any drivers. Any advice is appreciated.
Thanks in advance
Thanks in advance
