...QueComp (tel: 612-623-0903) should have out-of-business Applied Engineering
AEHD+ Drives for $99 (you may find one cheaper from flea markets or user
groups). Resurrect your old Plus or SE that does not have a SuperDrive without
having to replace the board in the computer (impossible on the Plus; expensive
on the SE). AE made three external floppy disk drives for Macintosh and Apple II
computers: 1. AEHD+ Drive - SuperDrive Compatibility for the Mac Plus, SE and
II. 2. AEHD 3.5" Drive - 1.44MB Drive for SuperDrive Equipped Macs. 3. AE 3.5"
800K Drive - 800K Drive for Macintosh and Apple II Computers.
The AE HD+ can read/write/format 1.4MB floppies on 800K floppy based compact
Macs. The Mac II requires an optional (not included) AE floppy interface to use
the AE HD+, since the Mac II case does not have a built-in external floppy
connector. A major drawback is that the AE HD+ cannot be the startup disk drive;
not as a 1.4MB floppy and not even as a 800K floppy. The other drawback is that
you've got to have the AEHD+ extension (takes 32K on disk) to use the drive even
as a 800K floppy drive (i.e. you must startup off another drive that contains
the AEHD+ extension). AEHD+ extension is compatible at least with System 6.0.7
and 7.5.5.
There also used to be Drive 2.4 from Kennect Technology that plugged into the
floppy port of a MacPlus and allowed it to use 1.4MB disks. It could also format
them to a proprietary 2.4MB size.
