Hi all,
So this is my first post, but I've been searching through and reading the posts for a couple of weeks, so I'd like to start with a big thank you to everyone who has contributed their knowledge (sorry I didn't make a note of the usernames to thank you personally) it's made my first classic Mac service a real synch!
I got my Mac a week ago and it runs absolutely fine, but I wanted to preserve the more at risk parts so bought a new hard drive, and a 4mb ram upgrade. When I opened it up, it was really obvious that it was the first opening since sale: thick black dust coated absolutely everything to the point you couldn't see cables or chips anymore! I decided rather than just remove the drive and ram, I'd give it a good old take apart and clean. Thanks to the guides here I was able I take it all apart, down to drives, logic and analogue boards, crt, video card and case without any problems.
I cleaned everything with an ESD brush and compressed air. I noticed that the bottom of the EM sheild had a large-ish patch of liquid residue, but I couldn't find any corrosion to the chassis, logic board and I can't see any signs of errupted capacitors or battery leakage.
I'm just wondering, whilst I have it in parts, if there are any steps I shoud take to look after it for the future? Any risky capacitors to watch/ should I look into replacing the battery as a preemptive step? I noticed that the 800k drive is absolutely buried in dust to the point I wouldn't want to use it, but in itself it isn't a problem as in the short term I have an external AE 1.44 drive that works fine, and long term I plan to put a 1.44 drive in the SE and replace the floppy chips on the logic board.
Any tips greatly welcome!
