I recently bought a Macintosh Quadra 700 off of eBay (https://www.ebay.com/itm/Vintage-Apple-Macintosh-Quadra-700-M5920-Desktop-Computer-w-Harddrive-Mac-iMac/273781054522?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649) and it has some corrosion on the logic board from a leaky battery. When I was cleaning the corrosion off, several components fell off of the board. The parts that came off were R71, C61, R76, R77, Y6, and C65. D5, D6, and U91 are still on the board, but their pins don't look too great. U92 has nearly all of its pins broken off and it is hanging on by two or three pins. I tested the continuity of all of the traces that I could follow in the damaged area and everything seemed to be connected. When I try to turn the computer on, the power LED lights up and the speaker clicks once (but does not chime). Do you think that the symptoms are caused by the missing parts or are the power-on issues more likely the fault of bad traces that I didn't catch? If any of the missing parts are necessary for operation, please tell me the correct component value so that I can replace them. I hope that U92 is not needed for the machine to power on because it seems to be a custom chip that is probably impossible to find. Attached are some pictures of the damaged area so that you can see what I am referring to.
I hope I can save this one because I have always wanted a working Quadra 700!
