Finally had this show up the other day, and I'm quite excited to get to work on it. Figured I'd start a new thread in case anyone wanted to follow along.
After it came out of its box and was set on the table plugging in the power adapter brought a happy bong sound, followed by some whirls and buzzes as it perked up. What I can only describe as a repeating "beee woooooo" sound must be its old Quantum drive protesting being woke up again. Eventually it gave up and went to the normal flashing ? disk icon.
Hinges are shot, they still are there but I likely won't be opening or closing this thing more until I find the time to take it apart and see whats going on. If anyone has any hints on hinge repair would love to hear them. Was thinking JB Plastic Epoxy on broken bits, but since its an XXXX I'm a little afraid to go to far with those types of repairs. Case also has a bunch of what looks like whiteout splashed about it. But some scrubbing with WD40 should get that to lift off.
Bottom had a neat sticker on it, sadly it doesn't appear to be anything special other than a low/mid spec QA unit unless its hiding some other secrets I've yet to find. Its side bay is filled with just a floppy module. Battery seems to be an off the shelf NiMH model and not a flammable lithium one I was hoping for.
Hopefully the drive can be salvaged and maybe with some playing around its contents can be recovered *knock on wood*. Would love to see some odd version of OS 7 on there, but would not be surprised if it was a release copy due to the wear and tear on the machine. Looks like it was actually used.
May try to give it a compact flash drive upgrade when time allows, that way can keep wear and tear off the original drive and set it aside for safe keepings.
Should be fun, I've never had one of these odd balls before. Can't wait to see it patched up and running like its old self again.
