Oops, misread your post above. Thought you said you tested the bad logic board in another SE and it worked.I tested another Logic board in the same computer and it works. So I doubt it is the analog board.
That is a neat trick. Is something like that available for the Color Classic? Can you point me to a link? Very cool!Get one of those ATX power supply extension cables. They fit into the logicboard power connector on the SE/30 as well and you will be able to run the logicboard placed next to the chassis.
