Hello
I got a PB 5300c recently, and as far as I can see only two things on it are broken (which given this models reputation, is probably quite good). The first is the battery which was at the early stages of leaking, caught it just in time before it did any serious damage, and the second is a diagonal strip of keys on the keyboard which are having none of it.
I'm not expecting it to be fixable and will use an external until I get a dead parts donor, although I had this specific diagonal failure happen to a corsair strafe after I upset a glass of water on-top of it and was just wondering if anyone knows what component may have caused this specific failure.
Otherwise, the machine is in superb condition. I can only assume it was docked for it's entire working life as it is practically blemish-less.
It's also got 8.6 on it, and had the memory bumped up to 42mb. Most resources on the model say to take it up to 8.1 for a solid performance so I'm considering bumping it down as I have something running 8.6 already
cheers
cheers
