Hi,
Just scored a 2001 iBook G3 for 40 € in great condition
It is a Dual USB (M6497) with a DVD drive and 640 MB of RAM, battery is completely dead after 17 years as you could have guessed
However, everything was working fine until yesterday.. :-/
I wanted to upgrade the iBook to Panther, plugged it and turned it on.
After a little while I noticed that little sparks were appearing inside the power cord that goes to the iBook near the plug (it has a yoyo power adapter).
After a while the iBook suddenly stopped and now I just can't turn it on anymore.
My guess is that the adapter might be broken because if I bring it near my ear I can hear a little click-click sound, even when not plugged to the iBook (short circuit ?)
Is this a normal behaviour ?
I hope that it has not fried the motherboard or anything like that.
Do you have any advice for a cheap adapter replacement ?
Thanks!
Edit: Another weird thing, of all the pictures I see on the Internet I can clearly see that the plug that goes into the iBook has a pin that goes a little bit out of the shield.
Mine doesn't and it has never been the case since I bought it
Maybe the little tip just broke into the iBook port, got to check this out later
Thanks!
