The voltages (5 and 12V) are to low! You could try to adjust the voltages with pp1. Sometimes the poti has some contact problems. But you have to look for the voltages for some minutes. they should be constant. If not, you have another problem on the board. If you get 4.85 V the classic will chime.
The fuse must be ok, because you can measure other voltages than 0V.
Look at the power connector on the board. Sometime the solder is broken. Reflow it.
Excuse my english, I am from germany...
Martin
Martin
