Anyone have the physical dimensions of the MDD power supply handy? I tried searching here and via Google and could barely turn up the electrical specs.
I would like to check whether this:
https://www.newegg.com/Product/Product.aspx?Item=9SIABP94VY8498&cm_re=1u_power_supply-_-9SIABP94VY8498-_-Product
power supply is a likely candidate to fit in the MDD either as a direct replacement, or by extracting the guts and placing them in the MDD supply's casing.
Image for MDD (electrical) specifcations:
