Hi Everyone in 68k World,
I'm new. I'm an amateur. I've learned a lot about soldering and electronics in the past 2 weeks. Primarily 1) Not all solder wicks are the same. Fine solder wick performs a whole lot better than course solder wick. This would have saved me hours and hours had I known. 2) I will never ever use lead-free solder again. The difference in quality of the weld and ease of use-- my crappy first attempts came out gorgeous once I changed solder. Who knew? Mac SE/30 after recap. Here's my current issue:
No bong, and that pattern.
I know it's not the analog board or the power supply. I have good readings across the multimeter (12v/5v). After recapping the analog board and power supply I was able to restart the computer and it booted.
This pattern is after the logic board recap. I've run as many traces I can find, particularly everything surrounding my work areas. All are making contact across the work area. I've used a magnifying glass to check for solder blobs or anything abnormal, can't see anything obvious.
I'm afraid I may have overheated a chip. When I was working on the 470uF axial, I had a huge problem getting the holes unplugged (see solder wick issue and lead-free solder above).
I am planning on checking the 8 video out pins once my oscilloscope arrives Tuesday. I know from Tech Knight's awesome video which pins to check, and I'm learning to read the schematics.
Any clues on what to check first? Anyone seen this before? I'm learning on the fly and know just how much of an idiot I can be. Enjoying the love/hate and embracing learning a new set of skills.
Here's the logic board now. The one trace jump wire on the bottom was on the computer when I purchased it 10 years ago. It tests fine.
