Looks like you needto build an additional adapter, dunno which settings you'll need. Played with what I could find at work last night,but haven't checked tha Apple pinout against my Mac Library.
No time for formatting, off to work.
Pin__SGI_______SGI__SUN SPARC__SUN (older)__VGA__Apple
A1___Red_______Red__Red________Red_______________Blue
A2___Green_____Green__Green__Green________Green
A3___Blue_____Blue__Blue__Blue_________Red
01___Mon 3_____Data clk. (SCL)___Serial Read___N/C___Red H.___Sync Ground
02___Mon 0_____Bidirect. data (SDA) V. sync N/C Green V. Sync Ground
03___C. sync___Gnd_______Sense 0 Sense 2 Blue Sense 3
04___H. sync___H. sync___Gnd___Gnd___N/C or ID bit 2 Sense Ground
05___V. sync___V. sync_________C. sync___C. sync___Gnd___C. Sync
06___Mon 1_____DDC 5v+ input___H. sync.___N/C (Red)___Gnd___H. Sync Ground
07___Mon 2_____DDC Gnd_________Serial write___N/C (Grn)___Gnd___V. Sync Ground
08___Dig. Gnd___Gnd___Sense 1___Sense 1 (Blu) Gnd___Sense 2
09___Dig. Gnd___Gnd___Sense 2___Sense 0___NO PIN (key)___Sense 1
10___Dig. Gnd_Gnd___Gnd___Gnd___(Sync) Gnd___C. Sync Ground
11__________________________N/C or ID Bit 0
12____________________________DDC Data (SDA) or ID Bit 1
13__________________H. sync or C. sync
14_________________________________V. sync
15______________________DDC Clock (SCL) or ID Bit 3
paste this into a spreadsheet, I'll finish the .TXT formatted later for posterity.
Pin SGI 13W3 SGI 13W3 (DDC) SUN 13W3 (SPARC) SUN 13W3 (older) VGA Apple
A1 Red Red Red Red Blue
A2 Green Green Green Green Green
A3 Blue Blue Blue Blue Red
1 10/03/14 Data clk. (SCL) Serial Read N/C Red H. Sync Ground
2 Mon 0 Bidirect. data (SDA) V. sync N/C Green V. Sync Ground
3 C. sync Gnd Sense 0 Sense 2 Blue Sense 3
4 H. sync H. sync Gnd Gnd N/C or ID bit 2 Sense Ground
5 V. sync V. sync C. sync C. sync Gnd C. Sync
6 Mon 0 DDC 5v+ input H. sync. N/C (Red) Gnd H. Sync Ground
7 10/01/14 DDC Gnd Serial write N/C (Grn) Gnd V. Sync Ground
8 Dig. Gnd Gnd Sense 1 Sense 1 (Blu) Gnd Sense 2
9 Dig. Gnd Gnd Sense 2 Sense 0 NO PIN (key) Sense 1
10 Dig. Gnd Gnd Gnd Gnd (Sync) Gnd C. Sync Ground
11 N/C or ID Bit 0
12 DDC Data (SDA) or ID Bit 1
13 H. sync or C. sync
14 V. sync
15 DDC Clock (SCL) or ID Bit 3
Holy CRAP! coldn't get the tab delimitation to work with earlier iterations of the spreadsheet!
edit: ditto, looked good in the .TXT window though. :-/
