Two questions regarding a recently recapped SE/30:
1. The internal speaker does not emit sound even after cleaning the logic board and recapping all capacitors. I've swapped speakers and checked that all power cables are properly attached. The audio out jack works, producing loud, clear sound through external speakers, but it makes a brief crackle on cold boot. What other points of failure should be considered? If the sony chips need to be replaced, are SE and SE/30 components interchangable?
2. While recapping C13, one of the pads peeled up slightly but did not lift from the trace. Could this be related to no sound or other problems in the future? The machine appears to run fine apart from its sound issue.
