Driver for DaynaPORT E/30
Does anyone know where I can get these? Or are they not even needed? I'm running a SE/30 machine with System 7.5.5.
To be perfectly honest I haven't tested yet. I got the ethernet adapter from uni yesterday and just barely had the time to install it but I plan to test it after work today but I hope to have a running start =)
www.macdrivermuseum.net seems to be dead. Only thing I've come across is a "DaynaPORT Installer.img" that might or might not do the trick.
Cheers, thanks. No luck though. Not sure if incompetence or hardware issues. Installed both versions and ran the diagnostics with a "bad address" error as a result =/
Better update here as well.
The "Bad Adress" error shown above is to be ignored. I've got everything set up and working now. Using OpenTransport, automatic DHCP lease and even automounting an AppleShare from my Raspberry running netatalk.
Using the 7.7.2 driver with System 7.5.5.
Running the diagnostics in this working state still throws the same error in my face, but obviously everything is running fine.
Bump!  Sorry to bump a (relatively old) thread - but does anyone have a disk image for the Dayna installer?  I'm trying to get my SE/30 up and running with the network - but no dice because I can't install the Dayna drivers.  The files don't quite fit on an 800K disk - and it's repeatedly telling me that my install media isn't genuine.  Very annoying - and completely unnecessary.  Bad Dayna!
Alternatively, is it possible to install manually - bypassing the installer entirely?
