I am coming here in hopes to get another perspective on my problem. About a year ago, I wanted to put a 68-pin SCSI HDD in my Q950 due to the original drive failing. Right before I left for college, I managed to format a small partition on the drive using my beige G3. When I came home, I started messing around with my Quadra again. I've had nothing but troubles with it, and I cannot figure out why. When I boot off a custom floppy image containing Mt.Everything, all it will show on ID 4 is "Error--Check Termination!!!". The drive is set for ID 0, and the drive is properly terminated with an active terminator. I even tried a vintage apple drive with the passive terminator and its giving me the same error.
Over at the MacRumors forum we determined: The HDD's, cable, terminators are fine, and we are getting proper terminator power. Since the host controller chips are connected logically, we don't know if one chip is fried due to the fact that if one is dead, neither of them will work. We also don't know if there is noise/interference in the power coming from the power supply causing a disruption in how the drives are getting terminated. Any ideas?
If anyone is interested in reading the forum post over at macrumors, here is the link:
http://forums.macrumors.com/showthread.php?t=1884497
