Just a quick question.. How can you upgrade the emate 300 memory.. I see an extra slot but not sure what is compatible with that slot... Anyone know what I should be looking for???
I bought a Canadian (I think) clone of the Newertech module. It works fine. Unless you are using the emate intensively, the standard spec is pretty good. You have to write an awful lot of notes to run out of space.
This is NOT the module for the memory expansion slot - it is OEM with every eMate.
The NewerTech modules do show up on eBay every once in a while and can be pricey. Its nice when a less-than-thorough seller lets an eMate go without knowing about an included treasure.
