Can KEGS read actual floppy disks?
Related question: is it possible to jury rig an external 3.5" floppy's internal cable into a Disk II controller board (is that what it's called?)? I haven't checked to see if the cable would physically fit.
I have 1 3.5" disk - Broderbund's Printshop for IIgs. I have one mid-1984 Apple IIe with a Disk II and RAM expander, and external serial 5.25 and 3.5 drives, and nothing else. I'm curious what some of the more outlandish solutions are.
8/vs/16bit software compatibility issues? I highly doubt itll work at all ever...
Unless printshop was compiled as an 8-bit binary for the IIgs' compatibility mode, (likely 16-bit which the IIgs is), it wont run.
No.  Different electrical interface, different control mechanism, different everything.  Well, they both read and write spinning Mylar with bits of rust on them.  I guess they have that in common. ;)
External serial 5.25 and 3.5 drives?  Wat?
Little confused myself, but here's my best guess.
A: KEGS the 2gs emulator can neither read nor write physical floppies for the reasons in the other thread. Hardware no workie.
B: By "serial" floppy drives do you mean the late model daisy-chainable drives with the db-19 plug? Short answer is "probably not". The 5 1/4" daisy-drives can in theory work with the old 20 pin header Disk II controller by mucking with cabling (most people want the reverse, though), but the IIgs/IIc+ 3.5 inch drives require one of those specific machines OR a special "smart" controller. The only 3.5 inch drive that might POTENTIALLY work with the disk II controller is the rarer "unidisk" version and even then... I'm not sure about that.
I was referring to the External 3.5", the External 800k, and the Apple 5.25" Drive.  The External 3.5" drive is compatible with both the IIgs and my Mac SE.  So if KEGS ran on my SE (which I don't think it does), this returns us to the actual thread-question... can KEGS read actual drives?  Because, Gorgonops, indeed hardware workie.
My IIe's cassette output port does not work - I know this because the power supply started to smoke after a half hour of trying to amplify the signal on my stereo (which did not work).  The machine somehow still works but it can't request anything, so I can't transfer data.  [being perfectly accurate, I think it does work, but the signal is infinitesimal.]
The only other thing I can think of is attempting to image the disk on SAMDisk since - and this was my original question, it doesn't appear that any Mac emulators/programs can read or image the disk.  I'm not actually convinced SAMDisk can do it and I keep pushing Mac because I suspect GCR issues - though I know nothing about Apple IIs.
(Techknight, fair point - I was more curious about the 3.5" compatibility in theory; I don't intend to try to run that disk on the IIe.  I'd also be amazed if it works, because it specifically says Printshop for the IIgs.)
If I am able to figure out a solution, I will lose a tremendous amount of faith in this forum - at least as concerns Apple II.
Unfortunately, KEGS (nor any other GS emulator) runs on an SE.  So it remains true, KEGS cannot read from actual (Apple GCR) drives.
I don't know what a SAMDisk is.  But if a Mac SE can't read it with DiskCopy 4.2 or DiskDuper - the original floppy is probably bad.
If you find a solution, you should share it and make the rest of us wiser...
I'll let you know if imaging the disk is a possibility in about 10 minutes.  Though it just occurred to me that it didn't work with the 5.25" Appleworks disk, so it's very unlikely it'll work with this one.
So, out of order:
That's a pretty rude thing to say, particularly when you haven't been overly clear about saying what exactly it is you're trying to do and what resources you really have at hand, leaving us to guess. Here's a suggestion: Try saying end-to-end what task it is you what to accomplish, IE, "I have a 3.5" disk from an Apple IIgs I want to copy somehow and run on an Apple IIe that only has a 5 1/4" drive; I have a PC with a 5 1/4" drive and a Macintosh SE, is there any way to make this happen?", instead of asking overly precise questions that don't really add up to the big picture.
And you said nothing about trying to use it with a Macintosh SE, you asked about KEGS, which unless there's some *other* KEGS emulator out there from the dark ages you're referring to only runs on 32bi+t Windows and UNIX systems. Getting frustrated because we didn't connect the dots and, uhm... wait, what are you talking about again? Apparently you know that KEGS doesn't work on your SE, so why are you asking if KEGS can read actual drives? There is no platform on which KEGS would run (other than *possibly* a very late model Beige Power Mac running Linux, and there I'm pretty sure there are driver issues) which comes standard with hardware capable of reading Apple GCR disks. So, no, the answer is that KEGS doesn't support physical floppies.
If you're asking if an SE can read Apple IIgs floppies the answer is "maybe". PC Exchange 2.0 and later as well as "Apple File Exchange" (going back to System 6) can read 3.5" ProDOS disks. Also, and someone feel free to correct me if I'm wrong, I *think* you might be able to use DiskCopy to image one. But that's not KEGS.
Note that the imaging process may well not work on nonstandard disks like self-booting programs or anything copy protected.
 SAMDisk
"Read and write almost any soft-sectored floppy disk format compatible with the PC floppy controller, including some traditionally copy-protected formats."
Apple II disks are NOT compatible with the PC floppy controller. Or, as I said when I assumed you were talking about KEGS running on a PC, "Hardware No Workie".
I apologize for being vague.  I want to read a 3.5" Apple IIgs disk.  That is my goal.
Subsidiarily, I was also curious if the Disk II controller was compatible with my other externals.  Purely out of curiosity.
I am aware that the PC disk controller is not compatible with Apple II (or Mac).  I was surprised it was able to successfully image and write Kaypro disks.  I was also surprised I was able to use it to read a 1.44 mb Macintosh floppy [this was either on a USB 3.5" drive or an internal one; I forget].  The 5.25" disks were all read and written on a 1985 Compaq Plus 360 kb drive.  So I figured perhaps I could image the Printshop disk for use in an emulator.  I didn't realize my aim was so unclear.
I asked about KEGS because it was the only emulator I was aware of.  The more likely target is Bernie ][.  In all honesty, I don't have my ethernet cable hooked up to my PM 7100, and I just ran out of CD-Rs, so I can't burn the "Starter Kit" that may or may not make the emulator work.  I have yet to find working copies of GS/OS, so if that doesn't work I don't know how much energy I'll waste on it.  However, it does appear that Bernie ][ can recognize the internal superdrive.  And I suspect it can probably read Apple II disks.
As to whether this is not the case or, in the alternative, the Printshop disk was not used to boot the IIgs, I do not know.  I will let you know tomorrow.  If this works, then it is possible to read Apple II 3.5" disks on many if not all post-400k Macs (or 400k Macs.  I yet know nothing of the format of the disk itself).  My SE cannot read the disk.  It probably doesn't have file exchange.  It's running 6.0.8.
I am aware that the PC disk controller is not compatible with Apple II (or Mac).  I was surprised it was able to successfully image and write Kaypro disks.  I was also surprised I was able to use it to read a 1.44 mb Macintosh floppy [this was either on a USB 3.5" drive or an internal one; I forget].  The 5.25" disks were all read and written on a 1985 Compaq Plus 360 kb drive.  So I figured perhaps I could image the Printshop disk for use in an emulator.  I didn't realize my aim was so unclear. <snip>
So, not to be too hard on you, but I think the last paragraph there sort of underlines the problem; you keep switching gears between multiple subjects with no transitions. Just in the bit quoted above:
#1: I'd like to know how to image a 3.5" Apple IIgs disk for use in an emulator without a IIgs.
#2: Can external floppy drives for a IIgs work with the "Disk II" controller, the one that just has the internal 20 pin connectors, in a IIe? (These two subjects were hopelessly intertwined in the OP, and further complicated by not saying "an emulator" but specifically saying "KEGS".)
#3. That third quoted paragraph: You referencing making disk images for a Kaypro... which is a completely different kettle of fish because a Kaypro uses an MFM floppy controller mostly compatible with the one IBM chose for the PC, also mention you were surprised that you could read a Macintosh 1.44 MB floppy drive with a PC floppy drive (Which actually isn't surprising; the "Superdrive" 1.44mb drive for Macs was specifically designed for PC compatibility and uses MFM formatting instead of GCR even when formatted with an HFS filesystem), and then I guess relate that seeing that those things could be done you thought you might be able to use PC hardware on a IIgs formatted disk?
So... yeah. Again, I guess it just seems you've been a little unclear on what you do or do not know and what you have to work with, and that leads to confusion and frustration and... bleah. I guess it happens to everybody.
Anyway, here's some baseline facts that might help clear it up all the confusion.
1: All of Apple's floppy systems prior to the 1.44MB Superdrive used a proprietary formatting system that IBM disk controllers can't handle. Thus without adding specialized controller hardware you can't read 143k 5.25" Apple II disks, 400 or 800k Mac disks, or 800k IIgs disks on a PC, period.
2: 800k IIgs disks use the same logical format as 800k Mac disks; therefore, the floppy drives in classic Beige Macintoshes *are* capable of reading them. (For the most part.) The old Apple II internet FAQ mentions using DiskCopy to manipulate IIgs disks; if I had my Plus set up I could try it for you and see if it works there (I have a few IIgs floppies lying around), but it looks like that's a legitimate option for reading a IIgs disk unless it's nonstandard or copy protected in some way.
3: Switching back the IIe, unfortunately, again, you're SOL trying to create disk images on a PC, and unfortunately the 5.25" Apple II disk drives can't be used on a Mac even though the plug is compatible so you can't make a bootable disk that way either. (The one edge case is if you had a Macintosh LC-family machine with the IIe emulator card, but in that case the Apple drive connects directly to the IIe card, not the Mac's disk controller.) You pretty much *have* to use something like ADTPro... which sort of sucks if your IIe is broken in some way that prevents it.
Re: your IIe, I'd suggest if you haven't already asking about your broken cassette port on Applefritter. There's a couple old crabby guys that might be able to tell you if it's fixable or not if you're willing to take a soldering iron to it.
I'm afraid I'll have to disagree.  I asked two very specific questions.  I then asked follow-up questions.
Techknight: Yea I didn't actually think about the architecture differences, but as I hope is clear, I didn't actually want to read that disk on the IIe.  I was just curious.
David_Schmidt: I'm pretty sure the only option is a Superdriven Mac.  I haven't gotten that to work yet, but I'm about to try again.
1.  Yes.  This is why I bought the PM 7100 - to transfer between my PC and my SE.  (Now I mostly just don't use the SE lol).
2.  On that basis, why wouldn't any Superdrive be capable of reading them?
3.  I was more curious about the IIe for broader reasons.  In theory, if a Superdrive could write 3.5" Apple II floppies, I could port stuff to it.  At the moment, with ADTPro not working, I can't really do much with it.
***I actually wanted to ask additionally if anyone is aware of a version or variant of ADTPro that just allows you to send data (disk images really) in the same way you'd send ProDOS or the Client so that the request doesn't have to come from the IIe?  If that feature exists somewhere or somehow then the next set of my follow-ups... how do I write a 5.25" Apple II disk without that feature working... will be rendered nugatory.
The problem is how you're asking them, but, well, if you don't agree based on what I've suggested (reading back your own posts) I imagine I'm not going to be able to convince you of that. (Notice that I'm not the only one confused by exactly what you're asking? No?) Anyway:
#2: Did I say that "any Superdrive" *wouldn't* work? No, I said that any drive capable of reading 800k disks should in principle work, so... what?
(At this point I just have to ask, just to be super-sure, are you clear on the difference between a "Superdrive" and a "normal" 1.44mb floppy drive? IE, a "Superdrive" is specifically a dual-mode disk drive PLUS an Apple controller that supports both the multiple speeds/GCR encoding of the original 400/800k Mac drives *AND* the standard 300RPM/MFM formatting used by conventional "industry standard" disks. Something like a USB floppy drive connected to an iMac is *not* a Superdrive even though it's a "floppy drive connected to a Mac".)
3: As mentioned *way* back, to use 3.5 disks on a IIe either requires a "Liron" controller card PLUS the A2M2053 "UniDisk" floppy drive, that *one* specific drive OR the drive you already have plus the "SuperDrive" controller (the description of this controller is right under 'Liron' in the previous link.). If you had one of those, yes, in principle you could write disks using your Mac that you could then use on your IIe. But you'll have to go shopping to get the missing parts if that's your plan.
(Of course, another thing you could go shopping for is a Super Serial card and avoid the problem with the audio jacks, but whatever.)
Good luck finding a solution for your mute IIe.
The short story is that Bernie should work, but the process is a bit circuitous.  At the end of all this, Bernie running GS/OS 6 could not read my disk.  It could read an 800k HFS floppy (shocker) but it couldn't format it to ProDOS.  Given that the Mac SE can (I know) format ProDOS, and I assume read ProDOS then, I'm guessing the Printshop disk is just damaged or corrupt.  I mean I guess the other short story is that given the older Mac ability to read and write ProDOS, this was all basically irrelevant except to confirm that the disk is screwed.
Silver lining, I suppose, is that if you have a machine whose File Exchange does not support ProDOS but which does support Bernie and has a Superdrive, you can read ProDOS disks through Bernie.  I gather the 'Write Protection' error I get in trying to initialize disks means you can't write to any disks - but I could be wrong.
Supposedly Bernie ][ the Rescue should be able to write floppies, although there seem to be some noise about disk exchange being less than completely reliable. Just checking: when you try writing a disk are you using a real double-density 3.5" disk, or are you trying to use a high-density floppy? A non-Superdrive SE is going to ignore the difference between the two but a Power Mac is going to care. (You may already be aware of this if you've been transferring data to the SE, but figured I'd bring it up. Your SE is the non-Superdrive equipped one, right?)
Bernie should be able to directly access floppies on machines with built in Superdrives (all beige box PowerPCs). Newer models tend to be flaky though due to cheaper floppy drives that have issues reading GCR disks..... find one that has a Sony built drive. That being said, beige boxes can image the disks using Disk Copy 4.2, which Bernie can mount and read. There are tools to convert the images into Apple II emulator friendly 2MG files as well.
Of course, if you have a real Apple IIgs, there are tools to make 2MG files direct from disk. ADTPro is the slickest as it handles getting the image to a modern machine with the least hassle.
BTW, The Printshop GS disk image can be found online. That's the easiest solution. ;)
I can fiddle a bit more next week.  I mean, my 7100 is from 1994.  I'd be surprised if this were a physical issue.  It's never had problems reading GCR disks (or writing).  The disk I was reading in Bernie was an 800k DD disk I use to transfer stuff between the SE and the 7100.  It is possible that the Write Protect error is equivalent to an error I sometimes get trying to initialize DD disks that I've already written to.
I assumed Printshop could be found online lol.  I don't actually have a medium for it and I'm not sure where I got it.  I was just curious if I could read it and if so what possible methods there were therefor.
It just occurred to me that presuming it is possible to convert ProDOS to audio outside ADTPro it should be possible to just use VLC. I tried this albeit unsuccessfully with my Commodore PET.
Okay.  I know I started this topic a while ago and badly but I'd like to again try to write a 5.25" floppy in ProDOS format.  The problem is, though ADTPro can download ProDOS fine onto my IIe (i.e. its receiver cassette port works fine), the IIe doesn't seem to be able to transmit a request for anything (i.e. problem with the transmitter port), so I can't for instance write disks (it's been a while since I've tested this but that is my recollection).
I don't care how, but I gather the easiest way is almost certainly going to somehow be through my IIe.  That's, unfortunately, the only Apple II system I have - it has a Disk II and a memory 64k I think (and probably column) expander.  I have a 5.25" IBM PC 360k compatible disk drive in a 32-bit Windows computer.  I routinely use my 64-bit desktop (I guess those details aren't really important) with a USB floppy drive and WinImage to 'burn' 3.5" Mac floppies (that's just the easiest route I've found).
If I make a ProDOS image, like in an emulator - like in Basilisk or Sheepshaver particularly, and assuming WinImage can read it which I think it will be able to, I think I should have no trouble writing 3.5" ProDOS floppies from my PC.  I don't know if someone can confirm this/if it's come up before.  In that same line of thinking, could I just use WinImage with the 5.25" drive...??  I never tried WinImage - or Transmac.  I don't think I've tried Transmac with my USB floppy.  But the 5.25" drive detects natively, so it may be usable by WinImage.  I may have time later.
You can't write 800k 3.5" or 140k 5.25" GCR disks using a standard PC floppy drive and controller. If the Apple IIe has a Super Serial Card, setup ADTPro via the serial port, it is faster and much more reliable. Super Serial Cards are VERY common if you need to get a hold of one.
