Defender of the Crown
I am trying to play the game Defender of the Crown on my Macintosh SE.  I got a copy from Macintosh Garden:
<snip>
The game starts fine and you can do some things however it always crashes if you try to buy soldiers.  Does anyone know what the issue is or have a working copy,
Thanks
Yes I should have mention I am running System 6.  I even downloaded another copy and it had the same issue.  Maybe you are right it needs an earlier version.  I was just wondering if anyone else had success playing this game.
Quite a few ancient B&W games need System 5 - I can't recall many off the top of my head, but Dark Castle II was one, and some flight sims.
No linking to Macintosh Garden. No Warez, period.
Oh yes, what I meant was I used diskette from 1987 I bought when I was 8 and tried to install it on my Macintosh SE running System 6.  Damn auto-correct replaced that with the link
Do any games require systems older than System 5, or that's as far back as one generally needs to go for most older B&W games?
I'm trying to create various boot disks for my Plus to run just about any kind of software, but I haven't bothered to create any older than System 5.1 because I haven't run into any software that needed it, but if there are games out there that need something older it would be good to know so I can create additional book disks in anticipation of possibly needing them some day.
I recall Fokker Triplane needed System 4.1, and that war game with the digitized sound for 128K/512K machines also used a very early release of System software - but it was probably to minimise RAM usage to run the game in the first place.  I suspect the version of Dark Castle II I have is very early, as surely that's one of the games that would run fine in System 7.  But the version I have needed System 5 (it came with a boot disk) again perhaps for lower resources to run it on a 1MB Plus.
I was under the impression that System 6 was basically compatible with everything made before it but I guess there are exceptions.  I will try downloading system 5 later when I have some time.
Ok, sounds like System 5 is the lowest one would need to go for most practical purposes. That's good. I don't find the versions before 5.0/5.1 to be very useable.
